Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 149
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 156
Eesti Skoda Klubi - 06a Superb rool raske ja keerates undab
Pealkiri: 06a Superb rool raske ja keerates undab (Vastuseid: 10 | Vaatamisi: 3261)
melkaleht
Registreerunud 31.05.16
Auto: Superb 2006a 2.5 120kw
postitati 09.06.16 15:52 Tsiteeri
Mure selles,et roolon raskem kui peaks ja kui rooli keerata siis undab nagu ei oleks roolivõimu õli!
Auto ostes oli roolivõimu õli otsas ja lisasin sinna uue õli (kuna korgil oli kiri,et peaks mineraal roolivõimu õli panema siis lisasingi mineraal õli)!
Օli kuhugile pole kadunud,aga undab nagu oleks kuiv!
Milles võiks viga olla?
postitati 10.06.16 10:25 Tsiteeri
Oleneb kui otsas see õli oli ,kui pump kuivalt käis ,siis hakka juba uut varuosa otsima.
melkaleht
postitati 10.06.16 12:17 Tsiteeri
Mis sa arvad kumb kuivalt käimisest õhtul on kas pump ise või latt?
rain
Registreerunud 26.09.14
Auto: octavia III L&K 1,8 tsi dsg
postitati 10.06.16 13:26 Tsiteeri
Latis pole midagi, mis undaks. Undab ikka pump. Samas mul audil nii, et kui põhja keerad, siis undab. Muidu mitte... Ning seda häält on teinud aastaid- las möliseb kui tahab :D
melkaleht
postitati 10.06.16 14:49 Tsiteeri
Algselt postitas: rain
Põhja keeratud rooliga undavad vist enamus või siis paljud autod,aga mul on rool ka kohapeal raske!
Registreerunud 21.11.05
Auto: traktorid
postitati 10.06.16 14:55 Tsiteeri
pump
melkaleht
postitati 10.06.16 14:58 Tsiteeri
Teab keegi kust saaks vaadata mis õli sinna sisse käib,äkki ei sobi see õli mis ma panin (täpselt peast ei oska öelda,aga mingi mannol mineraal õli panin)?
Auto: traktorid
postitati 11.06.16 06:47 Tsiteeri
manualis kindlasti kirjas.
arvatavasti peaks roheline lhm ametlikult käima.
põhjusmõtteliselt sobib suvaline prosta hüdroõli.
postitati 11.06.16 14:47 Tsiteeri
Algselt postitas: melkaleht
Teab keegi kust saaks vaadata mis õli sinna sisse käib,äkki ei sobi see õli mis ma panin (täpselt peast ei oska öelda,aga mingi mannon mineraal õli panin)?
Pentosin chf 11s
Nii väidab Autodata
Auto: traktorid
postitati 11.06.16 16:08 Tsiteeri
vai kurja, suisa täissünti nõutakse.
no ma võtan siis igaks juhuks oma sõnad tagasi.
võimalik, et on tõesti sistem seuke, et iga lödi sisse ei sünni panna.
postitati 12.06.16 07:28 Tsiteeri
Algselt postitas: diesel
Audidel ,volkaritel kasutati jah seda G00200 mineraali
[PHP: 40.3% - SQL: 59.7%]
