Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 149
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 156
Eesti Skoda Klubi - Vasta
 postitati 16.05.17 06:10
rahunege nüüd maha. kui kodanik ise kirjutab, et vahetatud sarniir on eelnevast erinevate mõõtudega, siis on ju asi tahe. õige tükk külge ja asi kombes.
 postitati 15.05.17 07:34
See ei näita midagi. Küsimus on, et kas amordi ots on õiges kohas. Idee poolest saad seda mõõdulindiga mõõta, näiteks diagonaale amordi otsast auto nurkadeni. Օige tulemuse saamiseks peaks muidugi kereremondi juhendi ette võtma, seal mõõtmispunktid ja kaugused kirjas.
Amordi kõverust ei pruugi auto all silmaga nähagi, endal selline kogemus olemas.
Kui on sillastendi väljatrükk olemas, siis sellega võib ju mõnes teises kohas käia uurimas, kas osatakse midagi kosta. Neid reguleerijaid ja remontijaid on ka igasuguseid nähtud.
2rni
 postitati 11.05.17 17:42
amordi otsad tulevad mõlemalt poolt samapalju kapotti alla
 postitati 11.05.17 17:15
Midagi peab sul seal esisillas korrast ära olema, et originaaldetailide paigaldust peaks modifitseerima hakkama.
Omast kogemusest niipalju, et mitu kuud ajasin taga vibrat esisillas kuniks lõpuks sai poolehku peale kõik õõtsapuksid ära vahetatud ja selgus, et ühe tagumise puksi kummist osa oli metallkorpuse küljest jahti ja voila- auto on jälle auto moodi. Mis katsetamised sellele eelnesid ei hakka rääkimagi (kusjuures Auto 100 oli väga abivalmis minu murega tegelema ja sugugi mitte ainult minu rahakoti najal, mis ei tähenda, et see mulle midagi maksma ei läinud aga müts maha) kuid tehaseseadistuse/paigalduse muutmise ideed küll ei tekkinud ja rehve ka õnneks ei söönud.
 postitati 11.05.17 17:14
Algselt postitas: 2rni
sarniiri vahetus tegi aint nats paremaks, ainus võimalus, mis ma näen, on et sarniiri auke ovaalsemaks puurida, muid ideesi pole
See pole nüüd küll normaalne lähenemine.Veermiku kinnitusi si puurita üle ega üldse ei ei peaks muutma.Tuleb ikka viga üles leida.
See koht ,kus sul m idagi reguleeriti on ilmselt alla igasugu arvestust koht.Kui sul külgkalle paigas ära,siis ei saagi sa midagi õigeks keerata.Esisillas peab kõik õige olema,see on kõik üks tervik.
Vaata üle amordi laagrid ja kõik muud puksid ja kinnitused.Võibolla sul üldse amordi pesa paigast ära.Või amort ise kõver.
2rni
 postitati 11.05.17 14:47
2rni
 postitati 10.05.17 15:36
eestis on olnud 3 aastat avariid ei ole olnud, ise kahtlustan, et sarniir, miks kuna ee näeb välja täitsa teistsugune, kui teine, veits suurem oli nagu
Raigo1
 postitati 10.05.17 14:26
Eesti ajalooga masin?
Mingit korralikku paukku pole saanud esiotsa?
2rni
 postitati 10.05.17 13:55
vasak esirattas, seestpoolt sööb, lasin kokkujooksu teha viljandis, siller auto ja tuli välja, et see rattas on liiga palju sissepoole viltu, katki ei ole midagi, nii öeldi teenistusest, paberi peal on kah nii kirjas
 postitati 10.05.17 05:29
Youtubest võib leida kõike, see ei tähenda et sellest ka reaalselt abi on. See "sööb rehvi" ei pruugi veel külgkallet tähendada. Kas esi või tagaratastel kas sisemist või välimist serva. Kirjeldusest palju ei selgu. Ja selle kirjelduse ja küsimuse vastuseks arvan, et viruta kuvaldaga, midagi ikka muutub ja siis saad jälle sama sügavmõttelise küsimuse esitada.
Mis nendesse videoklippidesse puutub, siis kogu materjal ja tegemine (ja valesti tegemine) ja siis jälle uute rehvide (ja võib olla veel millegi) muretsemine on kindlasti kallim ja ka mõttetum tegevus kui lähimasse silastendi sõitmine ja reaalse vea väljaselgitamine... :)
2rni
 postitati 09.05.17 20:27
https://www.youtube.com/watch?v=Ew87fLr6Omw leidsin sellise kah
2rni
 postitati 09.05.17 19:51
külgkalle on mul autol paigast ära. sööb rehvi. kuidas seda paika ise saada, leidsin youtubist video https://www.youtube.com/watch?v=wO1ZT5osWDw
mis arvate, mida tuleks teha, kas nii nagu videos?
[PHP: 66.6% - SQL: 33.4%]
